Here's the tech. data sheet for your model:
https://drive.google.com/open?id=1DPe34l9BUJbeMkUcAbyBZNdDs2McNTMp
Ok, I just noticed this model has the problematic door vent, that can also cause the 6-1 code and not wash.
Do this first--->Disconnect all the wire connectors to your door vent and see if it runs through a complete cycle.
Start reading what bigbuck said at post#18 here:
So after successfully running the one hour cycle with the vent wire harness disconnected, I ran the ProWash/ProDry cycle with the vent harness disconnected with 100% success.
www.applianceblog.com
Your model uses the exact same door vent. If it runs through a complete cycle and everything is back to normal, then order and replace the door vent assembly.
WPW10469574 Vent
To access the vent assembly you will need a T-15 torx screwdriver: Remove 4 screws (long) across top of door, then remove 10 screws (short) on the sides, then the outer door panel pulls off.
