- KDTM354ESS0
- KitchenAid
- 6-10 years
The dishwasher has been circulating water strongly then weakly every few seconds. Yesterday, it worsened to hear the motor running with no circulation for a minute or more (then would circulate again).
In running it multiple times today to diagnose, I noticed water on the floor. I diagnosed a leak from around the diverter shaft.
I verified the pump filter is still good (I already replaced sump&pump to fix a broken filter a few years ago).
Two questions:
1) Would a bad diverter motor cause strong then weak circulation every few seconds?
2) If yes to #1, would replacing the diverter motor likely fix the leak (i.e. most likely don't need new grommet/sump because higher water pressure in the area just forced out some water)?
Thank you!
Two questions:
Thank you!
