- KDTM354ESS1
- KitchenAid
- 1-5 years
My dishwasher won’t drain. I replaced the drain pump and checked all of the drain lines with a snake. Check valve in drain hose right at pump outlet is working properly. I can see water in the drain hose right after the pump. The drain hose loops on the side of the dishwasher assume like it’s own trap. I don’t see water downstream of that loop. Mia robot be enough pressure to push it over the loop. Drain hose ties in to sink drain just before trap and is clear. Removed screen and cleaned. Water will gravity drain out of the basin through the pump. I thought I heard the drain pump run at the end of the cycle but could have been the circulation pump. Any suggestions on next steps? Control board?
Also, what is the button sequence to run the diagnostic test?
