KEBC247KSS05 Cooling Fan making squeaking noise
SteelerNation
PA
Model
KEBC247KSS05
I have a Double Oven, Top and bottom convection ovens.
My cooling fan (NOT the convection fan) is making a high pitched squeak when I use the upper oven. Is this easy to repair?
It looks like there are two blower assemblies listed for this model?? I only see one of them in the parts diagram... I don't seem to see the dual oven model in any parts diagrams... Strange
I assume that if I'm using the upper oven it would be easy to know which one to replace, if there are two?
SteelerNation
PA
Now, looking into this, the sound seems to be coming out of the lower fan, as I hear it between the ovens.
However, the upper fan does not seem to be working at all... I feel no air flow at all...
Are these both the same part, or are they different parts?
THANKS!
Were both fans bad?
SteelerNation
PA
Not sure how to do your test. One isn't moving air at all, the other squeals. I'm assuming so...
The tech. data sheet that I posted tells you how to test them, but you'd need a multimeter to ohm test them.
The squealing one will definity be fixed with the new fan motor you ordered.
The other one that does not come on at all, you can ohm test it per page 5 of the tech. data sheet I posted.
