RogerCA
- KEBS209BWH00
- KitchenAid
- 1-5 years
Double wall oven will heat to the initial temperature in both ovens - say 350. Only a few degrees off using an external digital probe.
If you attempt a temperature change - to say 375 - oven display immediately shows between 305 & 320 and goes into preheat mode. Temperature does climb to past 375 and oven continues to show preheat but the display never gets above about 345 / 355 even through the actual temp is 388 - 390 and continuing to climb.
This is both ovens.
Temperature probe in upper over was replaced about a year ago. Control board (internal not the display board) was just replaced and both ovens exhibits the exact same problem
Adding that there is no foil or or there items in the oven.
Any thoughts are greatly appreciated
This is both ovens.
