KEHC309JSS4 KitchenAid - Microwave door latch doesn't lock fully - runs but doesn't cook
jharris82
troy, mi
KEHC309JSS4
Hello all,
KitchenAid Micro/ Oven Combo - Microwave door latch doesn't lock fully - runs but doesn't cook
My wife and I bought a house a year ago and it has a house full of aging KitchenAid products. One in particular is a KitchenAid Superba micro/ oven combo built-in. The model# is KEHC309JSS4 and according to the previous owners records, it was registered in June of 2003.
We have noticed over the last few months that as we walk by the built-in, the light to the microwave is on. When we push the door shut again, the light goes off. As the weeks have passed and no fix was made, it has progressed to worse. What happens now is that when the microwave is in use, we notice nothing is really cooking. If we push on the microwave door, we notice an added sound. That sound, seems to be the heating mechanism and now the food starts cook.
We're hoping this is an easy fix but am very new to DIY appliance repair. I have to believe its a door latch assembly so I'm looking for some guidance.
It could be a problem with one of the 3 door interlock switches or their mounting. There is no simple fix someone can just tell you how to do. It will require investigation and then determination on what is required to correct it.
Right now it should be a fairly reasonable repair should you call a technician in to fix it for you. Putting off the repair could lead to more extensive damage resulting in more expensive repair.
JMO
Appliance411.com
=D~~~~~~
