FIXED KEMC307KBT02 Kitchen Aid Microwave Door error?
Lordsandy
Plymouth MA
KEMC307K
Hello
I have a kitchen aid microwave and stove combo KEMC307KBT02 with “Door” error on the microwave.
I have replaced the 20amp fuse and all 3 door switches and still have the same error.
Where do I go from here? Any all help greatly appreciated!
Jim
Hi Jim,
The only part left that would cause this problem is the control board itself, but its No Longer Available.
Oven Control Board 8302346
Lordsandy
Plymouth MA
I found the 120V 15A fuse and a continuity test proved it was blown, however after replacement the door error still existed.
There are three door switches the single on the left if fine, the inner on the right is fine however the outside switch while testing without wires works correctly with wires I am getting some noise through all three terminals when checking for continuity, any thoughts?
Jim
I have no clue, I will ask Rick, he and Jeff know microwaves inside and out.
If the 20 amp fuse keeps failing there's probably a direct short somewhere. Since you replaced the microswitches, the monitor switch sounds like a good place to start. The monitor switch is a NC "dead man" switch. It connects L1 to N causing a dead short when the door is open. Always remove the wire from the COM terminal on the switch when checking continuity. Check the microswitches by opening and closing the door. Make sure the wires are on the correct switch terminals. If the microswitches check good, look for any obvious signs of a short (burned wires or scorch marks) then disconnect the two wires on the primary side of the transformer and tape the ends and check for a short across the two power cord terminals. My feeling is the problem is somewhere in the door switch and latch assembly. You may need to adjust the latch if the door opening and closing doesn't open the switch. That will also cause a door error.
Lordsandy
Plymouth MA
Hi
It’s not the 20A main bus but the 15A small bus fuse that keeps blowing.
Switches are all fine. Test them outside the door mechanism.
What would cause the 15A fuse to blow?
Thanks, Jim
Steve-
California
Thanks! Found it and it was blown. I've checked the door switches and replaced one of them. The control panel fuse is good, so hopefully a new 20A 250V ceramic fuse will get my 15 year old microwave back in action.
They wear out like everything else but with a microwave it's best to purchase 2 just in case.
