KEMC377KSS05 KitchenAid superba built in "DOOR" error message. Replace Switch?
Coneyman1
Michigan
KEMC377KSS05
Built in KitchenAid Superba microwave combo oven. "Door" error message even when door is closed, micro will not run. This has been an issue in the past, but " jiggling" door would fix it- at leas temporarily. That doesn't work anymore. Is it probably the switch? How hard is it to replace? I already have control panel unsecured. Is first step testing fuses?
Sounds like a bad interlock microswitch. To check/replace it, you'll need to separate the microwave from the oven in order to remove the side panel on the microwave and access the door switches.
Door Switch W10727408
