KEMS308SSS05 Oven/Microwave Combo quick start button water does not get hot
DeanD
Virginia
KEMS308SSS05
Good Evening,
When using the quick start button (pressing 1 for one minute) on the microwave with a cup of water in it, the water does not get hot. If I use Custom Reheat functions, things heat up no problem. Trying to figure out if a new part is necessary to have that function operational again.
I have no experience working on microwaves, I will ask Rick if he could help you.
Press 2 for two minutes. Does the water get hot? That's part of the control board on board program. You'll need to replace the control board.
Thanks Rick.:)
