KEMS309BSS00 Kitchenaid Microwave/Oven F6E8 Code
RockHonestRpr
Colorado Springs, CO
KEMS309BSS00
KitchenAid microwave oven combo with F6E8 area code. During my inspection of all the wiring, I found the 20 amp fuse, failed. I also found one of the interlock switch is on the right side was failed as well. I have replaced both a 20 amp fuse and the interlock switch. I reconnected power at the junction box exactly the way it was prior to an installation. Now when I switch the breaker on it immediately trips.
Jake can you find the tech sheet for this please?
