FIXED KEMS378SSS05 Microwave buzzing
nathans
LA
KEMS378SSS05
KEMS378SSS05 - Built-In Convection Microwave oven
This microwave is heating properly and functions as expected but has developed an annoying buzzing sound anytime the cooking is active or the fan is running after cooking has stopped.
When I push on the door handle I can alter the buzz and occasionally stop it. If I had to guess, it sounds like it's sourced from within the grill behind the door, slight left of center.
I have not been able to find anything obviously loose, and have tightened all screws available to me on the face/frame of the oven.
Cooking at 50% does not change the buzz at all.
Here is a sample:
Any ideas?! Thanks for reading.
I couldn't tell from the video. It sounds like a vibration noise so it's just a matter of finding it.
nathans
LA
Well, finally found some time to poke around inside and sure enough it was a vibration caused by these two blue components barely touching each other. Pushing one slightly away from the other instantly silenced the annoyance.
Thanks @rickgburton
