KEMS379BSS01 KitchenAid microwave isn't working. Tray doesn't turn and Timer freezes.
gstide
wa
KEMS379BSS01
Hi guys,
I have a KitchenAid Microwave/Oven combo. Model# KEMS379BSS01
The problem is:
  • the microwave doesn't work. It can't heat the food.
  • the tray doesn't turn.
  • the timer count down one second and then it stops.
  • after all these, the microwave continues to stay on for sometime then stops and show:
    • Err F1E5
      MW Inverter
I replaced the Inverter. But it didn't help. Nothing changed. All symptoms are same.
I saw some threads in this forum and other websites. Nobody seems mentioned the tray and the timer issue. So I'm wondering if I should try replace the control board W10577815, or try a new magnetron? Any further diagnose I can do before ordering new parts?
I'm new to repairing appliance, thanks a lot for the help!
There should be a 'tech sheet' in the unit with its wiring diagram to help diagnosing problems. Here's a PDF version.
It suggests testing the thermisters for readings and connections. If those test as Ok, the control might need to be replaced.
LINK > W10915648 Replacement Control PCB for W10577815
A failure of the magnetron tube should not affect operation of the turntable. It is unlikely to be the cause if both functions failed at the same time IMO.
gstide
wa
Thank you Dan
Finally I got a new meter to check the thermistors.
I'm new to this. So I'm not 100% I did the measurement correctly.
So, when the tech sheet says "check resistance of the thermistor", I should check the pins on the wire, not those on the board, correct?
If I did it right, the resistance is very close to the numbers from the tech sheet.
The tech sheet also says "check thermistor for short to ground". How do i do that?
what I did is I measure the resistance between the microwave shell and the pins. Both pins show infinite. So I guess they are not short to ground?
gstide
wa
Correction:
P21 is Magnetron thermistor
P22 is Cavity thermistor
gstide
wa
I took a short video. Hope it helps. thanks!
Yes.
The body of the thermister looks to be metal so measuring from either (or each) of its wires to the body of the thermister (or maybe its mounting screw) on the highest ohm scale would test for a short to ground. There should be infinite resistance.
Assuming the part that the thermister is attached onto is also grounded, that should be an adequate measure of a ground short. I'm not exactly sure where the thermisters are mounted.
I can't view the video. My browser says 'unsupported format'.
gstide
wa
Thank you Dan, I will redo the measurement when I get a chance.
here is the video link:
Dee I Why
Bedford, VA
Hello,
I have the identical problem on a KEMS309BSS00. What was the outcome of the above problem?
On mine, have tested everything recommended in the service manual and replaced the inverter (I put the old one back when that didn't solve the problem.) When the MW timer and turntable stop after a second or two I can hear a relay on the control board click. The relay that appears to be clicking is the top one on the left-hand stack that us connected to the right-hand door switch. I have tested the switches. Since everything from the thermistors to the switches has continuity, infinity, or ohms in the proper range, I am thinking the relay may be bad. Before I drop $200 for a replacement, is there anything else I should consider?
I really appreciate any help.
Tab (Dee I Why)
Dee I Why
Bedford, VA
Hi guys,
The problem is:
    • Err F1E5
      MW Inverter
Hi. Did you fix this? Mind has the same issues and I've replaced hundreds in parts with no success.
I wasn't the one with the problem. I don't know what came of it. Ask the original poster.
