twubker
- 106.51335710
- Sears Kenmore
- 1-5 years
The ice maker was making a loud clicking sound. I found that the gearbox case was cracked. I ordered a new ice maker assembly and installed it however it does not work. The ice maker tray constantly moves from the home position, stops 45 seconds then moves to the harvest position, stops 45 seconds then back to the home position.
I ran the service diagnostics at step 29 initially the "IM Harvest Cycle Is On" led is lit, but after 10-15 seconds, then the "Switch Fault or Motor" leds are lit. The motor is good as it cycles back and forth. I tested the internal feedback switch with an ohmmeter and it cycles open, closes at what seems the appropriate times during the moving of the tray.
I measured the voltage between the tan wires going to the switch and only get around 4.6 volts not the 12.7 volts that the service diagram shows in the table (P70-3 to P70-4). Do you think that the problem is with the main circuit board or the user interface board, or the new ice maker?
