Kenmore 110.25132410 Agitator Seal
ChesterD
Delaware
My washer had spinning problems After hours of trying everything, I ended up using a Dremel to cut off the hub, and the metal washplate gear.
With all the abuse, I'm a little concerned about the agitator shaft seal and was hoping to replace it.
If possible, to hold off until after Christmas to get a new washer, so a new gearbox isn't worth it.
Does anyone know if just the seal alone can be replaced, and if so what is it's part number? No part number for my model is shown, since it comes with a new gearbox.
The gearbox part number is W11454734, if that helps.
Thanks.
*I* have not seen any of those seals separate and they appear to only come with the gear box :(
jeff sr.
