- 110.26002010
- Sears Kenmore
- More than 10 years
Hi. My washer started acting up today, and I’m hoping you can help diagnose the problem. When I went to check on the last load, it had drained but the clothes were still soggy. There were a few Indicator lights flashing, but I don’t remember which ones specifically. I turned off the power, set it to drain/spin and everything seemed OK. The next load went through the sensing cycle, then started making a loud buzzing sound from the bottom of the washer. No water went in. I let it buzz for a minute or so before unplugging it. Now, when I plug it back in it buzzes from the top control panel until I turn the power on. When I try to run it, the same thing happens - sensing, no water, and then Buzzing until it’s unplugged.
The error code is F7E5 which I think is the shift actuator. Do the symptoms indicate that being the problem, or could it be something else? Any suggestions would be appreciated! BTW, I checked the pump, and it seemed OK. Thanks!
