FIXED Kenmore 110.26002012 Calibration Mode
Willyjay59
Missouri
I need to find out how to re-calibrate a washer I just replaced the gearbox/shaft assembly in. The machine has Part# W10468342A Service Tech manual which does not correspond with the Dial or indicators on this model.
It's the same process except your status LED's are vertical on the left side of your dial, instead of horizontal.:)
To access Calibration Mode, perform steps 1 and 2 of Activating the Service Diagnostic Modes.
Turn the cycle selector knob until the status LEDs or display correspond as follows:
--->“Rinse” LED On.
Then, Press the START button to begin washer calibration. All status LEDs will turn on.
Willyjay59
Missouri
I have tried the procedure over and over again but no success. I have done this on plenty other machines so I know the procedure. Every time I turn the knob on this one when it is in standby mode," plugged in with no lights showing" It goes immediately to what ever cycle you put it on.
Willyjay59
Missouri
I figured it out, you have to turn the selector knob 4 times counter clockwise to reset it, then 3 times clockwise, 1 time counter clockwise, then 1 time clockwise. Thanks for your help.
Excellent, good job. (y)
