- 110.26712690
- Sears Kenmore
- More than 10 years
Hello I am having a few issues with my Kenmore 110.26712690 top loader and hoped someone could provide guidance. It had been banging violently, and I discovered the "skate plate" was out of rotation so I corrected that, and now it has much improved. It still wobbles some in the spin cycle, but it is about 70% improved. However, in the process of fixing that (and changing the dogs while I was at it) I noticed that the tub spins pretty easily by hand when it is off, and it was my understanding that it should not turn easily by hand. Is this correct, and if so, what problem would that suggest?
I also noticed that when the spin cycle ends, the agitator stops, but the tub will continue spinning for several seconds. I read this is caused by a loose "tub" or "spanner" nut. I did tighten the nut, as it was quite loose, and this correct the problem one time. The next time I tested it, the tub continued to spin for several seconds again, independent of the agitator, after the spin cycle ended. I should mention that I do not have the proper spanner wrench and used a screwdriver and hammer instead, so perhaps that is the problem, or, can something else cause this problem?
I do like the machine - I have owned it since new and I would rather repair it than buy a new one loaded with electronics, so any help/guidance would be greatly appreciated!
