RickyD
- 110.64112200
- Sears Kenmore
- More than 10 years
My almost 20-year-old Kenmore dryer occasionally overheats to the point where it shuts off. Stress on the word "occasionally". It's very hot to the touch whether I use Low Heat Auto Dry or High Heat Timed Dry. In either case, my clothes are never damaged. Call it a coincidence, but if I put in a full load from the washer, 9/10 it runs properly without shutting down. Still very hot to the touch, but not shutting down. But if I put in something small like one or two pairs of jeans or a few towels, it will shut down more often than not.
When it does do it, I can either put it on Air Dry for a few minutes then go back to to the original setting to finish or I can open the door for about 3-5 minutes for it to cool down, start it back up, then finish.
Cycling thermostat?
Also, if it helps, when I removed the Chute to check for lint buildup (it was clean), I noticed that the foam padding between the chute and the bulkhead was pretty much non-existent.
Cycling thermostat?
