FIXED Kenmore 363.15171000 Draining Issues
Bridget Yost
VA
During the wash and rinse cycles the water doesn't seem to drain out.. it sloshes it out the front of the dishwasher...
At the end of the cycle.. all of the water will drain out and it will start the drying process.
the drain hose isn't clogged obviously... I cleaned the filters around where it drains out..
Not sure of the issue. I'm getting ready to sell the house and I don't want to have to buy a new one.
Thanks in advance!!
The timer controls the drain cycles on this model, so if its not draining except for the very final drain, then it sounds like a timer problem.
What I do to confirm this is remove the bottom access panel and watch the drain solenoid lever to see if it moves after the 1st wash cycle to drain, it should move DOWN to drain, and UP for wash.
There is a special note on this model:
IF DISHWASHER HAS THIS LABEL NEXT TO THE MODEL & SERIAL # PLATE
USE THIS LIST FOR CONTROL PANEL PARTS
(click to enlarge)
If that's the case for your dishwasher, then that timer is No Longer Available.
Let us know, because if that label is NOT next to the model & serial # plate, then the timer IS available.
WD21X10077 Timer
Bridget Yost
VA
So I took the front bottom panel off and it only moved at the end when it was draining...
So I order the part, does the front top panel where the buttons are come off for it to be installed there??
Thanks for your help!!
Yes,
Watch this video below, Your Kenmore 363 model is made by GE, its identical to the Hotpoint in the video, GE owns Hotpoint.
[video=youtube_share;wAOn4B7RPL0]https://youtu.be/wAOn4B7RPL0[/video]
Bridget Yost
VA
So I replaced the timer and it started spewing water out like it was, I turned the knob all the way through the cycles and restarted the dishwasher.. its not spewing like it was.. but it is still leaking a bit around the bottom on 1 side.. before it was a lot out of both sides.
Any more suggestions?
Ok, then check your right and left side door baffles, they may be cracked or missing completely, when you click the part links to them below, you will see a video on where they are located.
Here's the right side door baffle:
WD8X227 Tub Corner Baffle
Here's the left side door baffle:
WD8X228 Tub Corner Baffle
If thats fine, then check your bottom spray arm for cracks in it, that will cause this problem as well.
WD22X154 Spray Arm Assembly
Bridget Yost
VA
Ok not those. I checked those....
20190221_193818.jpg After looking in there more.. its coming from the side.. could the seal be messed up??
Bridget Yost
VA
The gasket up at the top around the corner seems very squishy compared to the other places. Could the gasket be bad??
Bridget Yost
VA
Got the dishwasher gasket today! Easy install and boom!!! No more leaking!!! Thank you sooo much for your help!!!!
Excellent Bridget, glad to hear the new door gasket fixed the water leak.:)
