Kenmore 596.77609801 Frost in refrigerator
Tayloorscott
Az
Have the kenmore 596.77609801.
Just noticed frost build up in the top back where the air blows in to the refrigerator. Temp reading 50 degrees and 0 in freezer. Freezer running fine no build up.
Fridge feels cold to me. Guessing might be a faulty thermostat or something?
Is your air damper fully open inside the refrigerator section? Click the air damper part link below and you will see a video of how to access it.
Here's the air damper for your model:
Damper Control Assembly WPW10196393
Tayloorscott
Az
That is where it frost builds up, but I don’t think it’s the issue. I thought someone had left the refrigerator open but today the temperature is showing 100 in the refrigerator when it’s probably 38
Yes,
Its possibly the refrigerator section thermistor. You can Ohm test it by using a multimeter to ohm test its resistance. At room temperature (77*F) the thermistor should measure about 10K ohms.
Here's the refrigerator section thermistor for your model:
12002355 Thermistor Kit
When you click the link to your thermistor you will see a video on how to access it in the refrigerator section.
