FIXED Kenmore 665.13293K114 - all Leds on and buttons unresponsive.
DKG
Boca Raton
665.13293K114
I have seen some posts that say the control board needs to be replaced. Just looking for confirmation and how much a new control board would cost.
Do this below:
- Unplug dishwasher or disconnect power.
- Disassemble door and disconnect keypad connection from control board or LCD display module.
- Verify all other connections to control board are made.
- Reassemble door, but do not close door.
- Plug in dishwasher or reconnect power.
- Wait at least 7 seconds for control board to power up completely.
- Close dishwasher door and monitor control board response:
A. If control board is OK (no longer sees stuck keys with keypad unplugged), it will respond by turning on the drain motor for 2 minutes. Replace keypad and console.
B. If control board is not OK (still sees stuck keys with keypad unplugged), it will not turn on drain motor. Wait for at least 10 seconds. If there is still no drain response, then replace control board or LCD display module (whichever one the keypad was connected to).
Here's the keypad and console assembly for your model:
WPW10333393 Housing-UI
W10482988 Electronic Control Board
DKG
Boca Raton
I ran the test and it worked like response A. I'll order the keyboard and console assembly and confirm everything is working fine after I install it.
Thanks for the tip.
Yes, that's correct, you will need the keyboard and console assembly if A was the response in turning the drain pump on for 2 minutes.
Yes, let us know how it goes.:)
DKG
Boca Raton
Replaced the Keyboard and Console assembly and everything is working good.
Thanks so much for the trouble shooting steps.
Excellent DKG, glad to hear the new Keyboard and Console assembly fixed it. (y)
