Redbullmoo70
- 665.13752K602
- Sears Kenmore
- More than 10 years
When running through a cycle overnight, it stopped mid-cycle. When I tried to restart, nothing happened. Some lights appeared to be very dimly lit, but nothing would happen no matter which button was pressed. I have reset it by unplugging for 10 mins. Now, the only thing that happens when I try anything is the drain will run continuously.
The lights are no longer dimly lit, but even after more resets I can only press the cancel/drain button and the drain runs. The micro switch for the drain tests OK and I have removed all water inside the unit by removing the pump assembly and disconnecting the hoses. Looking for what to try next?
Thank You
Thank You
