bmwbikerusa@net
- 665.14573N610
- Sears Kenmore
- 6-10 years
My dishwasher does not consistently fill with water. I can run the same cycle two times in a row, and the one time it will run perfectly, and the next time it doesn't sufficiently fill with water, as evidenced by the fact that the dishwasher detergent is still sitting in the bottom of the tub only partially dissolved. This happens with every cycle. It will run through the cycle, so if it hasn't gotten enough water, the food is baked on the items by the drying cycle. So, most things have to be handwashed. As stated, it doesn't happen every time. I replaced the control board, and I've checked for error codes, but there are no error codes coming up. Any suggestions as to what I should be checking/replacing to get it to work correctly every time?
