Kenmore 665.14573N612 Dishwasher Leaking after pump and heating element replacement
Lojack
Albany ny
665.14573N612
as I said above, my Kenmore 665.14573N612 Dishwasher stopped spraying so I replaced the circulation pump via YouTube and it worked but had no drying and was leaking from the bottom (mostly left). I replaced the heating element and that’s good now (not sure how I busted it) but it’s still leaking. I took the spray arm out rinsed it and water came out of the holes (not sure there’s a better test) but it’s till leaking and I’m beyond frustrated. Any advice would be appreciated.
Best,
john
Lojack
Albany ny
I should also mention, it also leaks when I tip it forward during a repair. The poly fill in the bottom gets soak and it drops out from there. Not sure that helps. I haven’t checked the bottom gasket.
Hi John,
Here is the wash motor assembly for your model, in case others need it too: W11084656 Motor-Pump
For the NO HEAT problem--->Run the SERVICE DIAGNOSTICS CYCLE, and let it run all the way through to reset it back to default.
--->Invoking Service Diagnostics clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle.
I'd do that now, and let us know how it goes.
You will need to pull the dishwasher out some and get a floodlight or droplight and pinpoint where that leak is coming from.
Lojack
Albany ny
Thanks so much. Could the heat be the reason the top dishes aren’t getting clean? The last time I tried all the soap was finally gone but a few couples smelled dirty. I’m thinking of throwing in the towel and buying a new one unless I can fix this thing quickly.
Lojack
Albany ny
Also, when I looked inside during the wash cycle, I didn’t see the arms moving but both contained water and were dripping.
Lojack
Albany ny
Hello Jake, yes. Thank you gain. The reset fixed the heat. However, the top rack is still not getting clean. There aren’t any obstructions so I have no clue what is causing this. I didn’t have this problem before the pump broke. Is it worth fixing further? That additional part was half the cost of the dishwasher and I’m surprised all that two parts failed at once.
Sounds like you possibly got a defective pump motor assembly, where did you get it at?
I'd contact the place you got it at and they should be able to exchange it for another new one.
I've replaced many of these same pump motors and all have worked perfect for my customers.
Lojack
Albany ny
Jake, that’s what I was guessing but I’m at the point of buying a new dishwasher. 2 kids and 2 jobs, it’s tough to wash all these dishes.
I bought it at parts Dr. I told them already I think it’s defective and I would need to mail it back and then after receipt I’d get a replacement. Not sure if it’s worth the time, any advice?
Its up to you what you want to do.
Lojack
Albany ny
OK, I’ll double down. I noticed the company that sent it to me, it said fits Kenmore but is a whirlpool. I replaced with an OEM, I’ll pop it in Tuesday. I just canceled my replacement dishwasher order. Thanks for all your help, Jake.
