FIXED Kenmore 665.1598791 not draining on final drain cycle
Josh223
United States
Ok so I did what you asked me to do and the machine does drain through the washing cycle it's just the last drain cycle that doesn't work.
Start the machine on a normal wash cycle. After the first wash the machine goes into a drain cycle. Check if the drain motor turns on. If not check if it's getting 120 VAC. If there is no voltage, replace the electronic control:
Control Board W10595569 Order now for same day shipping. 365 day return policy. RepairClinic.com
Does it wash and drain through the entire cycle but doesn't drain after the final rinse?
First check the drain pump/line and make sure nothing is caught in it. Exchange the control board for a replacement board.
Josh223
United States
The drain line is free and routed correctly. I took it off when this problem started and flushed it all out. I took the drain pump off and made sure there wasn't any broken impellers. I guess I'll take the board out again. Is this the ONLY thing it can be? Is there a water sensor or something that might be bad?
If it "worked perfect" for a while then stopped it sounds like the board again. Check for any shorts or bad connections.
sarahsez
California
Hi--I have a Kenmore model 665.13459 which isnʻt draining. When I hold down the Start button for 5 secs., it does go into drain mode--I can hear the motor working for a couple of chugs, then a pause, then it tries again, but no water drains. From reading all the above, it seems I troubleshoot differently depending on whether it has a separate drain motor or just reverses the single motor to drain. Could someone please tell me which my model has? Thanks
Also, on this model there is a backflow check valve in the elbow of the drain hose, if that is clogged it will never drain properly.
Here's our main thread on it:
That thread shows the black elbow which has the backflow check valve in it. Check it for clogs.
Kathryn and Tom found it clogged up, post #26 and post #27 and post #29.
Here's that drain hose with the elbow in it that contains the backflow check valve:
WPW10545278 Drain Hose
sarahsez
California
FIXED: It was a clogged air gap--I had checked the hose which was clear but I had missed a wooden match tangled up with a wad of gunky stuff right under the cap of the air gap.
