Kenmore 70 questions
ringlover
imported post
Model/Stock # is 96576200, S/N ME 1511348. Selector dial for choosing air dry, normal, heavy, etc. clicks and spins but will only operate/spin the clothes in certain places in the dial (air dry/ less dry). If I play with it, I can get it to turn for the selection I actually want, but it usually stops within a few minutes. I was hoping to find a fix for it b4 having to replace the whole thing. It's 10 years old but when I get it working, it still works great. Heats fine and all three heat settings work as well. It's gettin' it workin... Any thoughts...?
imported post
**Model/Stock # is 96576200**
Likely model# 110.96576200
**Selector dial for choosing air dry, normal, heavy, etc. clicks and spins but will only operate/spin the clothes in certain places in the dial (air dry/ less dry). If I play with it, I can get it to turn for the selection I actually want**
If you have to wiggle-jiggle the timer knob to make the dryer turn on....new timer time.
Easy to change! :) Power off first!! :shock:
Timer assembly for 110.96576200
