Kenmore 70 series electric, starts but dose not heat.
The Dude
imported post
Hello, Please someone help me!!, My dryers runs but dose not heat. I took the everything apart and cleaned all ducks which were very much clogged, all the way, I could not even imagine how air would flow through that, but any way I did clean everything, also I did reset circuitbraker, but still running cold. is there any fuse that needs to be reset !? or am I basically done and need a new dryer?what are the possibilities?? I greatly appreciate your help.
Sincerely Devin
imported post
**Kenmore 70 series**
Model#? Above isn't it. http://www.applianceaid.com/model.htmlSome model# helps.
**My dryers runs but dose not heat**
A copy:
Q - My electric dryer runs but will not heat, what could stop my dryer from heating ?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug ...
A ohm meter test for these parts is linked here
The Dude
imported post
Hello,
and thank you for your help, the modle # is 110-66722690.
it runs but dose not heat. I reset ciruit brakers.
THanks
Devin
