Kenmore 70 Series - tub won't fill
mbckmyr
Texas
I have a Kenmore 70 Series washer Model 110-20722-990.
The tub won't fill with water, it just drains right out. Can this be easily fixed?
I truly appreciate any advice.
Ok, whats happening is, its siphoning the water out into your home drain pipe as its fills, either you don't have a air gap at your drain stand where your drain hose goes into, or your drain hose is too low, it must be as high as the top of your washer before it goes into your drain pipe.
