Kenmore 790.36933905 - Oven works but display lights malfunction
ahnam
Minneapolis
Two days ago our oven, including display, turned off while baking. I checked the circuit box, and the breaker had been tripped, so I flipped it back and the oven turned back on.
Unfortunately, the display did not return to normal. Almost all of the lights (Bake, Broil, Clean, etc) stay on, despite the oven being off. In addition, parts of the clock/timer display are always lit, making it virtually impossible to read.
Any advice on how to repair? Should I just order a replacement part and move on? Anything else to try before spending the money? Is there a bigger issue?
Yes, you would just need to replace the clock oven control board.
Here's the clock oven control board for your model you can order:
ahnam
Minneapolis
I replaced the control board, but unfortunately the oven doesn’t hold a temp. In hindsight that may have been the case after the initial problem started. What next?
You never mentioned a problem with the oven not holding temperature.
So you had 2 problems?
Did the clock oven control board fix the lights display issue?
ahnam
Minneapolis
It did! I didn’t realize the temperature wasn’t working. I think it probably happened at the same time as the other issue, but am not positive.
Ok, got it! Thanks for clarifying that.
When you first turn the oven on, time how long it takes till you hear the gas/flame come on?
What I do is open the oven door first, then turn the oven on, then you should see your glow bar igniter thats located in the bottom of your oven(under the bottom oven panel) glow ORANGE then the gas/flame should come on within 45 to 60 seconds.
45 seconds in the normal average.
If it takes longer than 60 seconds, then it would be your oven igniter glow bar thats the culprit.
Here's the oven glow bar igniter for your model:
318177710 Igniter
