Kenmore 790.80323310 - Over the Range Microwave Stopped Heating Food
swb128
SoCal
My 2 yr old Kenmore 790.80323310 Over the Range Microwave has suddenly stopped heating food. Not sure what happened. The lights and vent still work. Any ideas what went wrong?
swb128
That's not a model number. Read it from the model tag on the machine. Kenmore model numbers look like XXX.xxxxxxxx
OK, Remove power from the machine. Check the door switches for continuity with your meter. Check them by opening and closing the door. Don't push the buttons on the switch. Check the TCO on the mag tube for continuity. Start a one minute high heat cook cycle and check for 120 VAC to the primary side of the transformer.
