FIXED Kenmore 795.76203.901 Ice buildup in bottom of freezer compartment. Ice cubes frozen together
pkeam
kentucky
My Kenmore has a bottom freezer. Ice builds up in bottom of freezer compartment. AND Ice cubes in ice maker bin freeze together into solid block of ice. I've read that this is due to clogged defrost drain tube from freezer compartment. The defrost tray beneath fridge is dry.
I've tried using a hair dryer but I'm not sure where to direct it.
Can I just turn off the FREEZER and ice maker only and keep top refrigerator running to let this thaw out??
Thanks so much
Unfortunately not.
Your Kenmore 795 is made by LG.
Here's the video: LG Refrigerator Disassembly
Start At about the 5:38 mark of the video, it shows you how to remove the freezer back access panel, then you will see the metal drain trough with the drain hole in the middle of it underneath your freezer evaporator coil, just melt that ice with a hair dryer and hot water, then run something down the drain hole. Or use compressor air to blow the drain hole clear.
I use a evaporator cooler spider snake to run down that defrost drain hole: https://www.azpartsmaster.com/products/24-evaporative-cooler-flexible-spider-snake_913
They are used basically in Arizona to clean out the water pump tubes that run to the cooler pads.
I don't know if they would sell them in your area, but if you go to your local hardware store, they should have something similar to run down your drain to clean it completely out.
Then run hot water and a little bleach down the defrost drain hole.
That should fix it for many years to come.
pkeam
kentucky
Jake, thank so much for your helpful reply. I'll now be able to address the problem
Peter
Sounds good Peter.(y)
