Kenmore 80 series 110.21884001 Noise, replaced motor coupler
kctickbait
Kansas City, KS
The machine has been making a noise during spin. This morning it quit spinning. I found a broken motor coupling and replaced it. I'm confidant, after 2 tries, the coupler is on there right but I have a noise during spin.
Take the agitator and inner tub out then try it on spin and see if the noise is gone. Check the drive block.
Use a 1/2" ratchet extension on it to remove it.
Let us know how it goes.:)
It looks like you're almost there. If you have the 7/16" bolt out, pull up on the bottom of the two piece agitator and both pieces will come out together. Occasionally they can be a real bear to get unstuck and off the agitator post. If that happens and you don't have a spare dryer belt laying around, pick up some small diameter but strong rope and a friend. Make a 4'-5' circle and tie it off. One guy on each side of the machine, put the rope around the agitator then push the sides of the circle under the agitator. Pull up at the same time. Make sure there isn't a light above the washer
kctickbait
Kansas City, KS
It has been running great until last night. Sounds like something getting in the way and catches, big boom and almost stops. Sure appreciate help in this matter.
Can’t open your video. Make a YouTube video and post it here. Sounds like something is getting in the way of what? Big Boom? Does it keep doing it?
Sounds like the motor stalls but I can’t tell for sure. There might be a bad spot on the timer cam where the contacts don’t make a good connection. Can you tell if the motor stalls?
Like Rick mentioned above, remove the agitator and see if it still makes that noise.
To me it sounds like the clutch is going south.
285785 Clutch Assembly
Rick watch the first video in his first post, the noise is non-stop there without that banging, that banging may be the clutch cam fixin to snap off.
Ok Gary, sounds good.
