Kenmore 90 Series Dryer 110.70912990 - Dimensions?
ackbosh
san diego
Hello all,
I have nerve damage in my fingers so unable to move the dryer to measure currently. I apologize for asking a simple task question.
I need to find out the dimensions h x w x d of this model dryer so the homeowner can replace it with a newer machine. Eyeballing it looks like the width is about 27 inches and depth the same. No idea on total height.
Any help appreciated it.
Robert4
Houston, TX
Does your model say King Size Capacity? That indicates a 7.5 cu ft dryer.
You are right about the width! Here are the dimensions:
Width: 27"
Depth: 28 1/2"
Height to top of control panel: 43 1/8"
The height is fairly standard, but current similar gas dryers (like Kenmore 72332) are 29" wide and 28" deep. There are some 27" wide models (Kenmore 71112 or 71652), but they are 29.88" deep.
I hope this helps!
Robert4
Houston, TX
You're welcome! How much space do you have around your dryer? You'll want to make sure you have enough clearance between the washer and dryer and the wall if you go with a 29" wide Kenmore model.
ackbosh
san diego
Right now between the side wall and washer there is 3 inches per side spare and behind dryer has about the same I would say. The washer is a new model and it sticks out a bit but nothing bad luckily.
