- 110.26912690
- Sears Kenmore
- More than 10 years
Trying to replace the suspension pads 285744 Have everything removed up to the inner tub. Spanner nut is off, lubrication soaked in. It won't budge. I can lift the entire assembly several inches but it does not move on the shaft. Have tapped with hammer & put flat head in slot on shaft for leverage & get no movement. Also, am able to rotate the tub by hand, drive block moves with tub while shaft is stationary. Any suggestions? Thanks.
