It is unlikely you will find the exact replacement. Someone will have to install a universal replacement like this one:
LINK > Universal Compressor Relay/Overload Asm
While it does come with installation instructions, someone should confirm the compressor terminals as they are not all the same, especially on older compressors.
Make a diagram and then measure the resistance between each of the 3 compressor terminals. Write down the results.
Between the
Run and
Start compressor terminals will have the highest resistance. The other terminal will be the
Common terminal. (Write it down.)
Measure between the common and each of the other terminals. The next highest resistance will be between the common and Start terminal. (Write it down.)
Between the common and Run winding will have the least resistance. (Write it down.)
PS. The overload protector is most often (but not always) connected to the Common compressor terminal so its mounting might help to confirm your results.
Also, test between each compressor terminal and a bare ground on the compressor body. There should be infinite resistance. ANY resistance to ground indicates a bad compressor. If you get infinite between any 2 of the
compressor terminals, it indicates a bad compressor as well.
You can then use the instructions included with the relay/overload package to wire it to your compressor.
