FIXED Kenmore Coldspot Refrigerator 106.53662300 icemaker fill tube freezing
Lalecob
Texas
I just started the icemaker back up after not using it for about a year (unit has been in operation though).
Icemaker will make about a 1/2 bucket of ice and then water is being sprayed on inside door, causing ice build up. Looks like the water fill tub is iced up.
That's usually caused by the water inlet valve.
Rick describes it in post #9 here:
Your model uses that exact same water inlet valve:
Water Inlet Valve W10408179
Your Kenmore 106 model is made by Whirlpool.
Lalecob
Texas
Thanks for the feedback. Problem is solved with replacement water inlet valve. Ice maker is working perfectly.
Excellent, glad to hear the new water inlet valve fixed it.(y)
