Kenmore Coldspot Refrigerator 106.55522400 - No Water to Icemaker
TarltonJ
South Carolina
Help!!!! Model 106.55522400. Not sure of the age. I changed the water valve and filter, then pushed hot water into the fill tube to make sure the line wasn’t frozen. The optics work fine (red light stays on when I push in the flap door). The auger works fine on the ice maker (fingers rotate as normal), it’s just not filling with water. The water dispenser works fine.
If that black rubber fill tube is clear, then I'd test the water inlet valve in the back of your refrigerator. Here's the water inlet valve for your machine:
Water Inlet Valve W10408179
This thread explains how: Testing ice maker water supply at the solenoid
If the water inlet valve tests good, then the ice maker itself is the culprit.
Here's the ice maker assembly for your model:
2198597 Complete Icemaker Assembly (8 Cube)
Here's the video to access/replace the ice maker assembly for others who need to know as well.
