Kenmore died
JETMORE
lusby
my wife simply rubbed the filter underneath and the entire microwave just died. no lights on, no screen reading, what the crapola?
anybody know what i need to do?
thanks a lot of piles.
ronny
Sounds like a coincidence.
just died. no lights on, no screen reading, anybody know what i need to do?
Checked the outlet plug with a radio or lamp?
House fuse/breaker, internal fuse, thermostat would be prime suspects for stopping everything from working.
Line-Fuse-W10138793--00566237.jpg Line fuse Manufacturer Number W10138793
JETMORE
lusby
Breaker is fine. How do i locate the fuse? Do i have to remove the microwave from the wall?
Normally the unit can stay in place, upper grill is removed and the consol ( key panal where you push in the selections ) screw is removed to lower the consol down towards you to access the fuse. #28 is the fuse.
