- 665.13203N412
- Sears Kenmore
- 1-5 years
Hello - My Kenmore Dishwacher model number 665.13203N412 that is only a few years old started leaking a bit ago, so i pulled the door off and ran a cycle to see where it is leaking from, and its coming through the build in vents in the door for some reason. I have ensured that it is installed level and I have checked the spray arm for cracks and there is nothing obvious that I can see that is causing it to splash out like this.
Most of the water gets caught in the trough below the vents and eventually seeps back in, but enough if the water splashes the inside of the door panel and then leaks onto the floor.
Anyway - the video here explains a lot better than words can. Anybody with some insight here would be greatly appreciated.
