- 665.13559K
- Sears Kenmore
- 6-10 years
Kenmore Ultra Wash Model# 665.13559K.
The High Temp, Heated and Cancel/Drain buttons light up if pressed. I can hit Cancel/Drain and you hear unit kick on to drain for about 20 secs then shuts off. Regardless of which cycle button I press, that particular button won't light up nor will unit start.
I opened up control panel on door to make sure latch was properly operating which it was. Made sure all cables/plugs were snug. Replaced panel. This unit is hardwired so I flipped the breaker for 30 mins and then came back to operate unit. The first cycle I chose was normal wash and unit came on, filled and started to wash. I hit cancel to drain. After finish draining, I tried to operate unit again and now I'm back to square one. No operation for cycles. Haven't tried the breaker again because that's gonna be a hassle if I have to every time!
