Kenmore Dryer 110.62972101 checks out ok still no heat
drglstewart
conway, arkansas
Older Kenmore 110 electric dryer no heat. Ive checked voltage in 240v, timer checks ok, all thermostats and heating element checks ok. Motor switch checks out. Ive started tracing wires and found some type of a "resistor" on the wiring harness that appears to have something to do with a relay (maybe) attached to the control panel black plastic I.5 inx 1.5 in with red power wires coming into then out of it directly to the last inline thermostat located on the heating element housing). This "resistor" is green about the size if a quarter and has no continuity across it. Im stuck. any help that I can get Id be greatful for.
Start reading what Rick says to do here:
You model uses that exact same heat relay.
Here's the heat relay:
WP3405281 Relay
