IndyAndroid
There was no plug on the igniter. Just two wires coming out and no way to tell which way is up. I had to cut the harness off the old one and put the wires into the harness. They have little metal tabs so they can be inserted, but not pulled out. Not sure if I got them installed correctly, can't tell which wire should be up.
I will look up the motor heat switch next, after I check the dumb wires. This is so super annoying, but thank you for your continued advice.
Andrew
Andrew
