Kenmore Dryer 72882
fatboyfan
imported post
I have a Kenmore Elite 110.72882110 dryer and it doesn't stay started and when you hold down the start button to keep it running, it doesn't heat.:( Any suggestions? I was going to by the Evenheat control board, but wondered if it should heat if the start button is kept on.
imported post
**but wondered if it should heat if the start button is kept on.**
Once the motor starts, the start switches job is normally over with....once the dryer is running the control board tells the heat and motor relays to close to keep the motor running and to tell the heat to work.
** it doesn't stay started **
Any beep noises when the dryer stops?
Something linked here may help.
fatboyfan
imported post
Any beeping noises-no none at all. Want to order online-best place, price and what part number?
