Kenmore Dryer 86980100 will not heat after replacing thermal fuse
charleSA
imported post
I have a 10+ year old Kenmore dryer (m: 86980100), will not heatand just replaced the thermal fuse to see if that was the problem. Still am not getting heat. What do I do?
:X
Two years ago I had the unit serviced (preventive maint) and all been fine. Recently, I have found, in the last few weeks, that if I used the timed drying the clothes had to be dried over and over to complete the process. But if I used the dryness selection method the clothes came out dry. Last week I found the clothes not getting dry via either method. Can you help?
DB130
, , USA
imported post
You probably have a dead thermostat or two and/or a dead heating element. A new thermal fuse won't help a no-heat condition. Do you have access to a multimeter?
I've had to repair two electric dryers this spring for family members. One dryer had a heating element die due to lint build-up in the dryer ducting and the dryer itself. The other dryer had a faulty cycling thermostat.
charleSA
imported post
Thanks for getting back to me so quick. I was outside puting up a clothes line until I get this fixed.
To answer your question, No I do not have a multimeter. Yes we had lint build up in the tray but is there more I need to do?
charleSA
imported post
Do I have to replace the box, thermal cutoff and heater-stat?
Or
Do I have to open the back and remove everthing minus the drum to clean the dryer out?
imported post
**86980100**
I got 110.86980100 to work for me.
**will not heat**
This here is from an FAQ section that has some common trouble makers for no heat.
