Kenmore Dryer 90 series
jscl
imported post
Hi, I'm trying to replace the circut board on my Kenmore 90 series model number 11068932790. Previously the dryer would only run when the start button was pushed down continuously. We've replaced the circuit board, plugged it in and the dryer will run immediately when the dial is put on a cylcle, without hitting the start button at all. Is it a wire on the motor relay??:? Thanks, Stacie
imported post
Possible either the start switch contacts are welded closed or the motor relay contacts are welded closed. Both should ( power off first ) show no continuity at rest and only show continuity when the start switch is pushed/turned or when the motor relay is powered.
