kenmore dryer model 110-96281100 won't turn off
mas
imported post
After changing out the thermostats and high limit cut-off, my dryer no longer shuts
down on a timed cycle. The heat element turns off but the dryer keeps runing until
I open the door. Do you think I reversed one of the wire leads on the thermostats
or the high level cut-off? any input is welcomed thanks
mas:(
imported post
mas wrote:
my dryer no longer shuts down on a timed cycle.
Does the timer advance to (or past) the off position or does just stick somewhere??
How does it work the auto or permanent press cycle(s)?
Your model uses a 'power resister'. On the auto cycle if it has failed the timer will not advance to the off position. I've never heard of one in the circuit on the timed cycle but may be possible. Check the appliance's wiring diagram.
The original resister may look like this picture from Jeff's web site:
(the arrow points to a failure point)
They have gone to a different style of resister as a replacement:
LINK > Replacement 'Power' Resister
JFYI
Appliance411.com
=D~~~~~~
