Kenmore Elite 665.12783K310 Blinking start light and blinking front display.
nickhiggins
San Antonio
665.12783K310
Ran 123...123...123.. goes thru cycle then ends with lights on 3 keypad buttons: Normal +Smart Dry+ Start. Have replaced control panel (keypad) and door latch. This last diagnostic cycle was run with the vent fan disconnected. If I buy a control board from this site, can I return it if it doesn't work? Thanks
What was the problem to begin with? Do ALL the buttons respond when you press them?
Won’t run and LED for Start/Resume key is Blinking Slowly--->1. By design, if the door is opened for more than 5 seconds or power is interrupted during a cycle, the user must press the Start/Resume key to resume operation.
Unit also will not drain if Cancel/drain button pushed. The keypad light for Cancel/drain works.
Do you hear any sound at all when you press cancel/drain?
I'm attaching the tech. data sheet for your model below.
Was ALL the wires removed from it?
