- 665.14752N510
- Sears Kenmore
- 1-5 years
Hello. I'm hoping someone can give further guidance.
Model is a Kenmore Elite 665.14752N510 made late 2016, early 2017.
The dishwasher will run for 5-6 minutes then stop, no beeps, no lights, nothing, just stops. When opening, there is water in the tub, but hitting cancel and closing the door it drains correctly.
Running diagnostics, error code is F8E4 – FLOW METER FAULT. The float moves freely and pulling the float switch out and testing for continuity with ohm meter it works correctly. Closed initially, pushing button down it opens. So don't believe it's the issue.
Have read that there is a door vent assembly that can cause this, but this model does not have that vent assembly in the door. I see where it would mount and the vent on the side of the door cover, but it is not there.
At this point it seems like it's the control board. However before purchasing a non-returnable expensive control board, I wanted to ask here to see if I was missing something or should test anything else first. Any other suggestions to check or can someone confirm the diagnostic?
Also, the control board is labeled as revision B. A few of the online control board pictures for sale show revision A. In finding a replacement, does it matter which revision?
Thanks.
Thanks.
