Kenmore Elite 721.79203010 frequent interlock switch replacements
ccupples
Texas
My 8½ year old Kenmore Elite 7920 microwave has been consuming interlock switches at an increasing rate since the first failure a little over four years ago. I'm now facing my fourth (I think) replacement. I've got another switch (two, actually, one for the current repair and another to have on hand for the next inevitable replacement) on order, but I thought this would be an opportune time to inquire whether there might be some underlying cause for the frequent switch failures. I recall the last time I replaced the switch it looked a bit scorched and the connector attached to the wires was a bit deformed/melted. (I'll post pics when I open the cabinet up to replace the switch once it arrives.)
Thoughts from the experts?
ccupples
Texas
Pics as promised. The interlock switch connectors don't look as bad as those going to the thermostat.
I'll see if Rick can assist you on this Microwave.
Both those components need new wire connectors installed. If trimming back the wires to an unaffected portion makes the wiring too short, that whole wire might have to be replaced.
The terminal(s) should have been corrected then. Installing a bad connector onto the terminal of a good component will usually shorten that component's lifespan, often considerably.
JMO
It's those stupid plastic wire ends that's causing the problem. I agree with Dan. Cut them off and get a few Hi-Temp solderless spade connectors. Cut the wire back until the wire strands shiney and not dull. I noticed something else in your picture that may or may not be a problem. I can't tell if I'm looking at an optical illusion . Are these heat sink fins on the mag tube bent out of place?
ccupples
Texas
I appreciate the input, guys. I will follow your advice and replace the connectors.
Thanks also for the observation on the heat sink fins. I don't think that's an optical illusion, but I have no idea how they got bent out of shape. Should it just be a simple matter of pushing them back into proper position to fix?
