Kenmore Elite 795.72489.410 Makes ice but won't dump into bin
KenZ
Northern Ky.
My ice maker is making ice just fine but won't dump into the bin. I can press the manual reset button for 3 seconds and the tray will turn and dump then it will refill just fine and freeze the cubes but will not dump again without pressing the button again. Could use some advice. Thanks.
I don't have the tech. data sheet for this model, but you have it right?
AEQ73110210 Ice Maker Assembly,kit
The tech. data sheet should have the diagram that shows you how to test the board properly. It should be located behind the kickplate grille.
KenZ
Northern Ky.
Haven't been able to find the tech data sheet for my model.
Not sure what you mean by kickplate grille. I don't see anything like that on my model
Pull the freezer drawer out and look at the bottom of your cabinet and you should see the kickplate grille.
If its not there, then we are dead in the water and you'll need to have LG come out to determine the bad part.
